primary timing chain tensioner replacement | Ford Explorer Forums
yong10mm
04 explorer 4.0 flex
can i reuse a new blade tensioner that has the pin pulled from it because i was replacing the blade tensioner and noticed the other guide was cracked so i removed the both blade and guide and re installed it and it seems to have a little slack in it now. do i need to replace the blade tensioner with a new one now?
If you have the engine out, replace all timing chain components.
