- February 12, 1999
- Austin,Tx
- 92 Nav, 99 Mounty, 98 Ex
Ok here is a problem I have come across with no luck on finding the solution.
The problem is with my Green Explorer with an A4LD. I just installed a used 4x4 A4LD into the truck for the 4x4 conversion. The transmission shifts fine into all gears with out problem. If I drive the Truck at higher speed(above 55) and after the truck has shifted into OD on coast down I get a sound I can best decribed as a dry bearing spinning fast. The sound does follow the RPMs. The sound does seam to be coming from the front of the truck and not the transmission but the transmission is the only thing I have changed.
Things I have checked:
Lose bolts
Front wheel bearing inspected and repacked
Checked all fluids trans and T-case
I did take the truck to a guy I know that knows a lot about Ford transmissions and he has never heard any thing like this on an Explorer.
Any ideas would be helpful
Lose bolts
