tricked04
- October 9, 2006
- '99 EB SOHC
I had delayed reverse and 2nd to 3rd flair (very bad flair)
I ordered the new Ford VB plate, ECC, bracket and also the sonnax valve, and the superior kit.
On the superior kit I ended up only using the epc update and the sonnax valve spring area update. I couldn't get out the mid bore plug (coast clutch thingy) so I didn't do that update. I removed that spring with silver plug and left all 4 balls and the spring with black plug. I also did not drill larger holes because I didn't know if the new Ford plate needed these.
The good: Reverse works awesome, goes in within milliseconds of selecting it.
The Bad, real bad: When put in drive the tranny starts off in 3rd gear than 4th and I don't think it goes into OD. IT DOES go into manual first and second when those gears are selected with the lever.
I figured I did something wrong any ideas would be more than helpful!!
