Problems with 4wd engaging | Ford Explorer Forums
boostranger
Rio Grande, NJ
91 xlt
91 XLT auto with push button and manual hubs.
Sometimes it works fine, other times nothing, and sometimes the light next to 4hi will light for a couple seconds and ou will hear relays clicking then the light goes off and no 4wd. Sometimes 4hi will work fine but 4low will not shift.
I finally got around to pulling apart the shift motor as that seems to be the most common problem, and i must say for haveing just shy of 200k it looked like brand new inside that caseing. not a spec of rust or dirt on any of the windings, brushes looked good, springs were in place.
I am at a loss, gona grab a switch next time at the yard and see if it helps, would apreciate any suggestions.
Thanx
Jon
Sandpaper the area where the brushes make contact. There is a load of info on cleaning the shift motors on this site and therangerstation.com. I did it to 3 motors that shifted sparatically and it fixed them.
What I did is get some oil and hook up the motor to 12v without the gear in place and i cycled it back and forth to get the oil to free things up.
hmm .. i guess i will have to pull it apart again .... it looked like brand new inside, not like most used electric motors i have ever seen .. no corrosion, rust, sand, or discoloration.
Thanx
Jon
did you figure it out?
i'm having a similar problem with my 4wd and would like any suggestions.
my 4x4 and 4 low buttons dont even light up anymore.
do a search on cleaning them. I did it to three of them and fixed them all- or you can go to ford and buy a $300 shift motor to fix it.
i had just about the same prob. a couple weeks ago and found the 4wd fuse had some corrosion, i replaced the fuse and started working fine
