Problems with a SOHC engine | Page 2 | Ford Explorer Forums
Tks for the help!!!
I will try to fix this.
Staying in contact
Stefan
O c'mon! I do drive a 2003 Mercury Mountaineer Premier as my daily driver... it still counts! I bought it since I needed some more power to be able to tow all my projects around... a nice V8 did it. ;)
New member here. Was not aware of the 00M12 kit and stumbled across this site (Google) AFTER I bought the upper & lower intake gaskets piecemeal from the dealer...... With the info from this post along with the links to similar posts, I was able to change out the gaskets in just a couple of hours with NO problems whatsoever!!! Next morning was below freezing and it started up and idled PERFECTLY!!!! Thanks so much, you guys have saved me a lot of money and headaches!!! :)
Great Trailbum!
Happy that it help.
I'm waiting from my side for the intakes.. I will change it also myself.
It look like not too complicated!
Steph.
Stephane... next time let me know if you need anything for your Explorer... I do supply parts for American cars to a few people in Poland...
good luck with your fix...
Hello Mike,
thanks for the help, I've check this.
Fuel pump is ok as same as filter.
Best rgds,
S.
