Problems with engaging 4x4 | Ford Explorer Forums
Uppsala
Explorer, 1999
Hi!
I am helping a friend to sort out some problems with his 89' Ranger SuperCab.
We have just change almost the entire rear suspension and major parts of the suspension mounts on the frame.
Now we have started the big task off solving some electrial malfunctions.
The 4x4 will not always engage when the button on the dash is pushed.
There are some sounds from the electrial motor on the transfer case so the thing isn't totally "dead".
Last winter he had the same problem but when he changed battery the problem was gone. Bad battery - lack of power to engage 4x4...
But now the battery is in quite good condition and the problem is back.
Can this be caused by a faulty button on the dash? Bad groudning?
Faulty control unit?
Any ideas?
Thanks in advance!
Best regards
Gurra
Uppsala
Sweden
So it engages sometimes? Any patterns you notice during the times it DOES engage? i.e. like will it only engage when the truck is warmed up, or will it only engage in any other specific conditions?
The 4x4 engages now and then. No specific conditions. It doesn't matter if the transmission is warm or cold. Therefore I believe it is a electrial malfunction such as a bad ground connection.
//Gurra
So you're gonna check it out with the test probe?
