FreedomRun
- February 12, 2008
- '91 XLT 4X4 XLT AT
I have a 1991 Explorer 4 door XLT. It has the push button 4x4 system. I had the transfer case motor replaced last winter because it died. I also had manual hubs installed. Now, I'm having problems with the automatic engagement system.
I push the 4x4 button up on the dash and can hear the click back at the module on every single push, but it can take up to 50-60 pushes for the 4x4 to engage. Then, if I push the button again to disengage it might take 6 pushes to re-engage the next time, then maybe 25 the next time, and so on.
What is the issue here? Is it a bad module? What can I do, or what would I tell my mechanic to test or check out?
I'm very disappointed with this automatic 4x4 system overall. It's just too darn complicated for what it's supposed to do. Is there any type of modification for drilling through the floorboards and attaching a metal rod to the transfer case for a manual engagement? Or maybe that's just wishful thinking.
I need my 4x4 system to be reliable and engage everytime I need it to engage, as my livelihood depends on it. So therefore, I am very grateful for you sharing your knowledge, expertise, and advice with me. Thank You.
