Projector Headlights | Page 2 | Ford Explorer Forums
Have you tried turning the adjusters as shown in pic #33? Are they not working?
no not really and i might put the old adjust back in to see if that will help and are the adjusters like screws or like a type of bolt
For the led style projectors they are a bolt... no need for the old adjusters, just turn the adjusters with a wrench. Pull up to a wall and adjust :)
ok so i doing it right and for the screw to come out would be it going down right and i have the spyder auto headlights if that helps some too and i will try it tomorrow again and how long is the adjuster screw
If your headlights are seated well they should be pretty close already...you will know right away if you are turning the adjusters the wrong direction.
in a way i cant and they shot up high though but i will get it figured out tomorrow
ok now i figured out where the adjusters all i was seeing was the high beam ones so now they adjusted
Good to see you got them aimed. Here is the pic from StraightKill showing both adjusters
yeah i no and he just shows you the ones that go up and down the other set of screws it the left and right ones and i going to get a pair of silverstars so the heads can be alittle brighter
