donkey boy
- April 16, 2000
- Rome, GA
- '01 WJ
I had some bad luck with good brand name fog ligths in the past (Cibié) and decided at that moment just putting cheap stuff in the future. Now, I found some decent no-name ligths which are 100 Watts. I want to put them instead of the original fogs and I was adviced on this board not going higher than 55 Watts, because the Ford harness, switch etc. might not be able to handle more.
Here my stupid question: Can I replace the 100 Watt bulb by a 55 Watt bulb and should be fine? I know, the light will not be the same, but ...
OK, I'm probably making a fool out of myself with this question, but if you answer it without laughing, I promise to answer some more stupid tire questions.... deal?
