PTU/Trans Leak Passenger side Axle | Ford Explorer Forums
ULDlose
Lyndhurst, NJ
2013 Explorer XLT 3.5 NA
History.
PTU was replaced roughly 3 years ago at 56-58k. Under 5/60k drivetrain warranty.
Present day.
The Explorer now has 113xxx on the clock. I was in the garage and noticed a few spots on the floor where the Explorer rests. When my wife came home with the car I stuck my head under and noticed that the PTU had a oily film on it. I was able to to get a little smear on my finger of course sniff test it and it doesn't smell like gear oil more like Trans fluid threw it up on the quick jacks and couldn't really pin point the leak as the bottom as the bottom of PTU is wet and so is the Trans near the PTU. Fast forward a few days and some research and FSM reading and the evidence of oil sling on the Passenger side of the PTU, I'm pretty sure its the intermediate shaft seal. 2 out of the 5 local ford dealers quoted me 700 to 1000 to do the job but that is only speculation with out of course a diagnostic fee. I have been searching around and could get the required tools and parts for around 4 to 500. Most of the tools I can use to also service my 14 Escape and the Explorer again in the future if need be, so it makes a little sense the upfront cost is so high considering the seal kit and a few extras only come out to like 40 my cost. I have considered just changing out the PTU but I maintain the fluid in it every 20k and it comes out dark but still flows well(I drain/extract and fill it 3 times using the FSM procedure) and very little to any metal particles in after straining the old fluid.
I think that's everything and one to the question.
How many here have attempted this repair successfully? Should I be looking for a underlying issue as to why this seal failed or is it just a poor(S**T) design like the rest of the PTU on Fords part.
Update. Decided to go under car and spray the hole thing down with brake clean to get a better idea of where the leak is coming from. It's definitely the passenger side and migrating over to the bottom of the transmission case. Interesting finding the plastic dust shield moved while spraying brake clean. Reached up and I can free spin it only feeling a slight bit of resistance at certain points of rotation.
So now I'm at the point of. Do I bother replacing the seals and dust cover or for a few hundred more just replace the entire PTU with a new FORD unit roughly 700.
I think you should pinpoint the source of the leak for sure and the oil type before making any plans. If unable maybe a shop with a lift can do it. If it is trans fluid I would only fix that seal, as your ptu only has 55k miles with several fluid exchanges already. It should be in good shape.
is it gear oil or tranny fluid?
Either way its a big job.
If it's tranny fluid the seal inside the shaft/gear on the blue shop towel are leaking. The axle shaft goes through this into the tranny. If it's gear oil then the seal on the PTU cover (on the ground behind the blue towel) is leaking.
If you have time/abilities I'd do it yourself and change all those seals.
My dust shield spins around and feels useless as well.
I have a very small gear oil leak just behind the dust shield...my install...so its on me. I'm not about to pull everything again. I added a drain plug so gear oil swaps are easy now. I'm doing changes every 15k miles or so. Considering that thing only holds 3/4 of a quart I was a little worried with a small leak. But I just did a 5000 mile change to see how much I've lost and it was almost nothing. I'll continue to monitor...push comes to shove I'll pull it and change the seals again.
IMG_9074
You may want to fix your comment. Ptu capacity is 18 oz (~1/2 qt), not 24 oz (3/4 qt).
Also, dust shields can, and often do, move.
The seal is $20 from Ford and a couple hour fix at most, book time is 3 hours and even if you have never pulled an axle before it should take at most 4 hours. I don't see where the design issue is with the PTU, just a simple gear box, positioning not the best with the cat right there is the only downfall I currently see, but time will tell
True....you can do the PTU seal with the PTU in the truck. Watched a couple of online videos and they have a special tube you use to seat the seal. Probably can do it without the special tool with some help. I may break down and do that at some point...on the rainy day list.
Socket with correct diameter and an extension, put it in through opening left from the axle.
with my luck that would work and fix the gear oil leak...then I'd promptly have a problem with the axle seals upon re-installation of the axle. But definitely doable.
Well I cleaned up the PTU with brake clean and it has been dry since the day posted this. I have no changes in level of the trans fluid and PTU oil. I keep checking it everyday as its easy to see with out lifting the truck and will be rechecking the fluid later in the week when I have time to throw the truck on the lift. While it is true the PTU seal is easy to change and so is the intermediary shaft seal you need the right tools to do the shaft seal, need the puller and installer for it. Pull the axle do the PTU seal and not change the axle seal you'll probably end up doing the job all over again.
The design flaw is the lack of easy preventive maintenance, the close proximity to a catalytic converter and low amount of gear oil used in it. Last I checked they are on revision G of this particular PTU, and yet still no drain plug still the same amount of fluid. Just a few changes to bearings and trust washer designs. Other than that its a simple gear box that cost way to much to fix and has short life span, If it had a drain plug it and a regular maintenance schedule it might stand a better chance at lasting longer.
Some of the newer 2016+ Explorers do have a PTU drain plug.
History.
Present day.
Okay so I have a 2011 ford explorer limited 3.5l 4wd I’m having a issue with a transmission leak an I know it’s coming from the passneger side of the transmission where the axle goes through the ptu unit into the transmission. So my question is is there a seal between the ptu unit and the transmission for the axle shaft or is the intermediate axle shaft seal for the ptu unit the seal that will fix my leak. An if there is a seal between the two can someone point me in the direction to get it
Just wanted to say, Welcome to the Forum. :wave:
I'll leave your question to be answered by more knowledgeable members.
IMG_9074
Hi so I have a 2015 xlt 3.5 awd and am having a transmission leak on the passenger side where the cv axle goes in and I see you have the ptu torn apart. Do you have to tear the ptu apart to replace the seals or can it be done from the outside. And if so do you have any tools and strategy recommendations? I'm at a dead end so to speak as far as finding anything on those seals and replacing them. Any help would be greatly appreciated!
Yeah....if you have a tranny leak then the seals you need to replace are between the tranny and PTU.
Yes...you need two of the "7H469A" seals....they go in back to back, if i recall the first one goes in with the backside facing to the outside and then you put the second one in with the backside in first so the backside of each touch. The other seal "7H469B" goes on the outside of the ptu and butts up to the tranny. I don't have a pic of the new parts, but do have pic of me taking the old outer seal off adn you can see the inner seals still inside the housting.
I have the PTU apart to do this, can't recall if you can do this with it assembled or not.
Took a quick look in my spreadsheet and I have the seal between the PTU and Tranny noted as Crush Seal (between tranny & PTU) p/n 7E5Z-7H469B.
I also have a note saying PTU Seal Kit includes all seals on axle side of PTU p/n DB5Z-7275-E.
I did all the seals since I had it apart.
I actually had to replace the outboard side (passenger side of PTU) seal later as I damaged it when changing the axle. It alone was p/n 7T4Z-7R284-A Transfer Case (PTU) Output shaft seal.
You are a life saver man. I appreciate your help. I actually know what to do now haha. I'm a diesel mechanic so I have that going for me i just haven't done many cars in my time as a mechanic haha. Thanks man I really appreciate it.
No worries.... agreed, doing it is one thing. But finding out what the heck to do is another. I dug that stuff up on the internet at some point but was never really sure until I tore it apart. Glad someone is finding the info useful.
I did find one more picture that I think will help. The crush seal and one inside of the cover in the pic above are NOT what seals the tranny fluid (that seal is on the ptu housing and stops the gear oil from leaking out). The part numbers and quantity i mention above are correct. But the two seals go inside this gear (pic below) that the drive shaft slides through. in this pic you can see the two seals installed. They seal around the driveshaft and stop the tranny fluid from leaking out that way. It's been a while.
