ftexplorer
- September 20, 2005
- Caldwell, NJ
- 00 XLT
I have a 2000 Ford Explorer XLT 4x4. Recently, the coolant has started leaking on the passenger side near the firewall. I checked the oil for coolant, and it doesn't look like it exists. I can most likely say it is not a head gasket. It looks like the leak is coming from underneath the evaporator core (the thing that looks like it is wrapped in aluminum foil). I looked underneath the car and can verify this. Also, the the wheel well piece that is held by plastic plugs is wet on the left most plug. So the leak is definitely coming from behind the wheel well. It only leaks after the car is started and has had a chance to pressurize the cooling system. My next step is to get the wheel well off completely to look and see. I've read about others replacing their heater control valve and fixing the problem. I don't have a heater control valve that I can see, so it might not be on the 2000's. Does anyone know what radiator hose/tube is located where I am describing, which is under the evaporator core and behind the wheel well?
