Pulling EEC-V codes | Ford Explorer Forums
Pulling EEC-V codes
dstig1
Hudson, WI
'99 V8 AWD
I know this is a dumb question, but I really would like to confirm what I suspect. My other car is a '92 SHO, so I am familiar with EEC-IV and how to pull codes using the CEL. The '99 Explorer V8 is now throwing a CEL for the first time, and I went to pull codes but scratched my head as to how. From my readings here, the best I understand is that the ONLY way to pull codes on an EEC-V/OBD-2 car is via a scanner (of which there are many types), and the CEL light method no longer works.
Is this correct?
It seems like nobody has come out and said this point-blank, but it appears implied and/or common knowledge to most around here. Sorry, but I'm still stuck in the early '90's, I guess.
Thanks,
Dave
Why don't you just have Autozone pull the codes for you? You wouldn't have to buy an expensive scanner. I don't know if that CEL method would work on the OBDII vehicles. Even some scanners don't pull all of the codes that are vehicle/manufacturer specific.
Yes, a scanner is the only valid way to pull codes out of a OBDII vehicle.
-Drew
bump,
Is still the case w ford? I only ask for my you can check my 2003 chrysler with cycling the key on-off three times?
