They are pretty easy, just mark the position on the shaft and wheel so u can put it back the same spot. A puller may be required but maybe not. After you remove the bolt holding the wheel on the shaft you may be able to bump and pull the wheel off without a puller. i forget if the 93 has airbag or not, if yes you need to disable it first. no need to break your face over it.all the parts have to come off in a certain order and you need torx bits and 1/4 ratchet, extension, deep-well and shallow-well sockets, a magnet tool, a pick, needlenose pliers, phillips and flathead screwdriver. Columns are aggravating, take your time, be very careful and take your time.
If that is a tilt column it gets more complicated, there are 2 pins with threads inside them- One on each side of the column that you need a quality puller for. be careful, if you break the puller threads off in the pin you have to drill into the housing beside the pin so you can get a chisel in there.
