puzzled | Ford Explorer Forums
puzzled
RottenEggHead
1998 Mazda B4000
My Mazda B4000 has an intermittent problem and I am assuming it is electrical in nature. From a stop light the truck started lurching. The cluster panel was flashing all kinds of lights. I was a couple miles from home so i used back roads. Today it is running fine. Any ideas what this issue could be? I did take it to Autozone and they used the code scanner but nothing kicked up other than a known O2 sensor problem. This also happend about three weeks ago. The next three weeks it ran fine. I would think if it were a transmission problem it would be an everyday thing.
Yes I sure did. I will check the ground connections. I was possibly thinking the ignition switch could be faulty? I know its a stretch but maybe possible.
Nice of you to let us know how this came out. Helps other when they have the same problem.
