xz96
- June 7, 2014
- 1999 explorer sports 2wd
I heard that when mountain driving, it's better to put transmission on 2nd gear and turn Overdrive off to help breaking.
I have an old used 5r55e automatic transsmion.
1.does it put extra pressure on the transsimion if i use 2nd gear or turn OD off? i know it's gonna eat more gas, but will it increase the possibility that the transmission break down while driving? i certainly dont want to breakdown in the mountains..
i never use 2nd gear or turn OD off before, always put it on D, but im going to colorado next week which means a lot of mountain driving I-70, 550...etc
2. is it normal that after i switch transmission to D from P, there's a very small vibration noise coming from the transmission? as soon as i give gas, the vibration's gone. it's barely noticed, if i turn on audio a little bit i cant hear it
my mechanic couldn't find the problem, should i be concerned about this small noise?
3. what is the speed range for 2nd gear?at what speed should i change from D to 2nd?
4. will it damage the transmission if i change from D to 2nd a lot while driving?
thanks for all replys!
