wr2001
- October 13, 2010
- Pomona ca
- 93 limited
I changed out the oil pressure sensor two weeks ago because the gauge was not working. Luckily pressure returned and everything was back to normal. I only drive my 93 Limited 2wd 12 miles a day or 15 max with store trips.
This past weekend I drove more than usual and noticed that every time i was idling at an intersection the oil pressure gauge would drop all the way down and just dance around. Once i accelerated or took off the gauge would return to normal. I'm guessing i have to change the oil pump??? But the car is overheating as well?!!!
It seems the axle is in the way, is it necessary to pull the engine? I really dont want to, but is the oil pump the only thing to change out? I really dont want to mess with the block. or rebuilding it.
