blk88
- June 16, 2008
- Phoenix, AZ
- 1995 EB
I have the issue that after searching seems to be somewhat common. I have a 95 Ex and got the code 646 that says 2nd gear failure. It takes a while to shift into 2nd gear and only does so after I let off the gas. After searching I came across adjusting the intermediate band. Here are my questions: there is an adjustment for the intermediate band and the o/d band. Now one the tranny which one is which? Since I wasn't sure I followed the instructions on this write up http://www.explorerforum.com/forums/showthread.php?t=158160&highlight=adjusting+4r55e+intermediate+band and adjusted both back 2 turns. My other question is would 1/2 a turn make a difference since the write up says 2.5 turns back? Also, is there suppose to be any tension when you back these out? After backing both out 2 turns there was no change. My last two questions are: can I adjust them more and what if adjusting the bands doesn't solve my issue. Could it be a bad solenoid? Thanks for any advice.
