Quick question on brake rotors... | Ford Explorer Forums
Ranger379
middle of nowhere, PA
'99 XLT 4X4 4.0 OHV Auto
hey guys, gotta do brakes here asap, anyway i never bought brakes before, so for a dumb question, does it matter what is currently on my explorer as to where i have to buy rotor and hub assy. or just the brake rotors, thanks guys!
bump... anyone, need to get some brakes today or tomorow. thanks
If you are just doing the pads and rotors, you don't need to be concerned with the hubs. Here's the procedure:
1995-99 4-Wheel Drive Models
Loosen the wheel lug nuts.
Jack up the front of the vehicle and support on jackstands.
Remove the wheel and tire.
Remove the two anchor plate-to-steering knuckle bolts then slide the assembly off of the rotor.
Grasp the rotor and pull it from the wheel hub. Some models may have a small retaining screw holding the rotor to the wheel hub, if so, remove the screw then pull the rotor off.
Installation is the reverse of the removal procedure.
ya, so dont matter if last guy bought the hub/rotors, i can still just buy the rotors only, just wanted to make sure, dont have time for tiral and error lol
