jonboyb
- April 18, 2017
- Alpharetta, GA
- 2003 Mounty 4.0 2wd Base
I know there's a million posts and I've read them...but never found one quite like mine. I have a 2003 Mountaineer 4.0 2wd I picked up from my FIL about a year ago as a beat around vehicle...only has 135k miles. Been driving it for maybe 6-8 months now daily to keep commute miles off my truck. A few weeks ago, I had the passenger door open when I cranked it, and at startup heard a distinct rattle...for just a millisecond at startup. It's silent at all rpm's...none of the horror stories on the 2500-3000 rpm rattle. It will not make the noise again unless the vehicle sits for an extended period...like 3-4 days or more, and you'd never notice unless the doors are open or standing outside the vehicle when cranked.
I'm certain it's timing related, I can let it sit a few days then do the full-throttle oil priming procedure before start-up and it's silent. Seems like the tensioner(s) just bleeding down after extended sitting. I'm an avid mechanic and normally I'd just tear in and replace the entire timing component suite, but we all know this engine is a bear to get to the rear components, and trying to diagnose WHERE the rattle is when it only does it for a split second on start-up after sitting for days is near impossible. Buying factory parts not exactly cheap either.
Am I overthinking this....considering its just a beat around car and only doing this after long term sitting? Had I never cranked it with the passenger door open....I wouldn't even be posting this....LOL. Thanks.
The only other thing I might add is my FIL's dealership had been using 5w-20 in it for as long as his records show (he bought new) but he had it changed religiously at 3000 miles. I did put it back on a diet of 5w-30 Motorcraft when I bought it from him at about 125k miles.
