I don't know either? Just something I read on this forum. The outers are removed, and I intend on using the inners that come with rack.
Finally got the socket I needed, 15/16, for the lower bolts. So got those off, and disconnected the 2 lines running to the cooler. I've located the bolts that need to be loosened to lift the engine mount, and located the pinch bolt on the the steering arm, but haven't loosened yet. I'm wondering did you pull out the rack with the lower steering arm attached and the other thicker line running up to a pulley? If not where did you disconnect the arm and that line at?
It would be the bottom right line. It's a hose that is connected to a hard line that has a plug that is connected to a pulley/pump? I've also got the pinch bolt off and the nut at the bottom of the steering rod, but seems to still be connected as well?
Ahhhh! So I can just disconnect at the rack. Duh!
Now I just need to figure out how to separate the steering arm from the rack? Pinch bolt and bolt at the base are off, but I can't figure out how to disconnect. However, it's nice that I can rotate it enough now to get to the inner tie rod bolt as I think I'm going to take those off. I would think it's going to make it a lot easier to get the rack out. I'm going to go with the inners on the new rack anyways.
