rack & pinion ? | Ford Explorer Forums
rack & pinion ?
csrpn
Houston
'00 XLS
greetings all,
i own a 2000 xplorer/xls (92k miles)
anyhow, the rack & pinion has started leaking (very small amount)
the local auto-check wants to charge me $750 to replace it.
does this sound reasonable?
on a related note, how much longer should i continue driving - with this leak?
at this point, i can't tell that there's anything wrong with the rack & pinion or anything related.
thanks, c
Try some power steering stop leak first.
As far as price you can buy a referbished Rack from Advance for $130 but it will take most of a day to swap if you have never done one before.
Does that quote include an alignment? An alignment will cost you around $70.
If the leak doesn't bother you then you will be fine just don't let it run dry.
The alignment is included in the quote.
Anyhow, most things bother me - I will try this first: http://www.lucasoil.com/products/display_products.sd?iid=28&catid=2&loc=show
(as per the recommendation of another member)
If the leak doesn't disappear, I will likely have it replaced. Unfortunately, I can't do it myself (no tools, no garage - at this point).
Thanks for Replying
