tristram77
- October 11, 2000
- Staten Island/ Boscawen ; NY/ NH
- '92 XLT 4.0
My X has been having some problems with the cooling system. I will look under the hood and the resavoir will be empty and open the radiator and see that it is low. then i will drive home to add some coolant and the resavoir is at the cold fill line and the radiator is fine.
Today i flushed it and and added some "Coastal stop leak/ seal rejuvinator" to it. Everything seemed grat. i folled the directions of all the products to a t. i then drove it about 15 miles and with it running but at a stom the resavoir was overflowing and pouring on the ground. I turned it off and popped the hood. looked and there was a full resavoir and it was pouring out. i then let it sit for a moment or two and drome about a half mile and popped the hood. the resavoir was empty. i took off the radiator cap and the radiator was low. so i let it sit for 30 minutes and drove another 15 miles. i get home and the resavoir has a bit of fluid in it and the pressure in the radiator is quite high.
Any suggestions?
The coastal stuff had may it sorta sudsy and was a little odd. it had the pellets in it that needed to be dissolved but as i said i folled the directions to a t.
Any suggestions?
