OK, in my angst to find a 6.5" replacement and reading someone on this newsgroup did the same thing - I ran over to radioshack and bought the "woofer" and not a subwoofer I was thinking it was.
I recently upgraded to a CD player head unit by Jensen and 4 speakers by Blauplunkt, the sub went south about two weeks before this. Well I didn't really like the sound from the sub anyway, too much distortion, the new 3 way speakers have nice clarity but not the bass umph, the woofer adds what was missing without the distortion.
So no it's not the audiophile system with a subwoofer, but it's better than having nothing back there. It sounds pretty good even if it does not run at full power since it has more resistance.
Spec.
40 Watts RMS, 80 Watts max
Poly cone driver
13 oz. magnet
56-6000Hz
85dB
8-ohm
Update: OK it's been a couple of weeks since installing. I read on this newsgroup about polarity of the subwoofer and changed mine and it does sound better. I don't know what the definition of sub-woofer vs. woofer is, I looked at subwoofers on Crutchfield and the frequency response of the Kenwood 6.75" is 30-3,500Hz and the 6.75" Rockford is 58-250Hz. This "woofer" is within that range although has a higher top end. Speakers frequency is 45-22000Hz and the human ear can hear from 20Hz-15kHz, it appears to me the "woofer" has a response for the lows we humans can hear. The only draw back is it's 8 ohm instead of 4 ohm, but I can't tell the difference, the poly cone vs. the stock paper cone is much better. Again if you want to replace the stock "woofer" don't discount this at $20, Cruthcfield 6.75" will need alteration and are $79 and $129. If you have 2000-3000 watt system no you won't be satisfied unless you have 2 or more 12" thumpers.
