radius arm bushings advice | Ford Explorer Forums
silver
Boerne, Texas
1994 Sport
any advice on replacing radius arm bushings on a 94 sport please?
use a lift. and get polyurithane bushings so you dont have to do it again.
Personally I find that drilling the old rivets out and replacing them with grade 8 bolts is the easiest way to do this. As others have said there are soe real good threads on here about this.
^^ hes right
maybe some advice do a sas swap i replaced my radius bushings greased um anti seazed them an they sqweak worse then a old horse and buggy rig
i should of left um alone lol ohh well :((
I hear use 7/16 from some and use 1/2" Grade 8 bolts from other which is the correct size ? I know you want them tight in the holes to prevent shifting...
yeah and how long should the bolts be?
thanks
Don't use polyurethane unless you don't mind noise and a harsh ride.
7/16x1 inch ...put the nuts on the outside of the frame...
