MustangShane
- October 30, 2003
- Lake Orion, Mi
- 1991 4dr XLT 4x4.
I just got in from replacing both radius arm bushings and what a pain. I read up on replacing them in my manual and it all sounds so simple. Remove spring, detatch sway bar, unbolt radius arm nut and it all just slides right out with nooooo problem. BULL
First you remove the spring, detatch sway bar, unbolt radius arm nut and dont you know it they have perssure to the outside of the hole so they will only move out so far. So I tried wiggling it up and down to work it out and nuthin!!
I used a pry bar to try to force it out and they dont give you a good pry point. ARRGGHHH this sucks!! I ended up using my come-along to pull the pass. side forward and some how I pried out the drivers side. Then I used the come-along attached to the opposite side of the truck to pull the arms inboard so they would slide back into place. Lets just say I was VERY relieved to be done.
After it was all said and done I'm very happy I did this. I'm sure others probably have stories similar to mine.
