radius arm tourqe? | Ford Explorer Forums
radius arm tourqe?
tigercat
Perry, Fl
'92 sport
hi what is the radius arm bushing tourqe i installed a 2 inch lift and the bushings dont completely contact the bracket?
I gave up torquing those bushings.. Nowadays I just use my impact wrench (my cheap one that won't go over 200 lbs) and crank it down..
I use rubber bushings and they seem to last even when I do this.
Autozone.com has the repair guid for the 1st gen x's on their site which should have the torque settings for the RA to the RA bracket.
~Mark
ok i looked on autozone.com and it sais 90-120 ft lbs but if i do that would it make the bushings flush with the bracket and if so would the pressure lower the suspension at all?
anyone know?
anyone know?
The pressure won't lift/lower the suspension.. If you don't have it torqued down you "could" get more suspension droop as the bushing will be looser, but thats not a good thing to do..
~Mark
