ranger 8.8 vs explorer 8.8 | Ford Explorer Forums
jeffseal
Alpharetta, GA
95 xlt
are the axle housings the same diamter? are the ubolts interchangable?
the axle tubes are the same diameter and you can use the u-bolts. if youre going to be using a ranger axle in your explorer you'll have to move the spring perches, theyre set wider on a ranger. also the ranger axles arent as strong as explorer axles. theyre 28 spline while explorer axles are 31 spline.
need some 3" lift blocks.
I have a 31 spline 8.8 out of a 2002 FX4 ranger. Yes I said 31 spline for the last time.
