Ranger rims on an Explorer... please help. | Ford Explorer Forums
Mainfraim
Los Angeles, California
'94 Eddie Bauer
I found a guy that is selling a set of 2000 Ranger 15x7 rims. I've got a 91. Are those compatible with each other? I don't want to have a hassle putting my tires on them. Thanks.
Yes, they will fit on your truck but you will have to drill out the center on 2 of you center caps in order to make room for your hubs.
Come to find out the Ranger is 2WD, does that cause a problem? I figure the only problem would be the center caps if anything. Am I correct? Thanks.
Yes they will bolt up.The only problem should be the center caps.
yeah theyll work you just need to do the center cap thing and your set
Wouldn't you have to do all four in order to rotate??
it should be just like anything else, you'll have to switch the center caps when it comes time to rotate. just get 2 stock OPEN center caps and you'll be on your way.
Come to find out they're not the rims I thought they were. Still looking for a new set of rims (preferably a set off of a 95-2000 Explorer if anybody's got 'em). Thanks for your help though guys.
I have a set from a 96 if you want them. But they do have tires on them, and they only have 2-3,ooo mile on them. e-mail if you want to know more about them.
