SensRanger
- September 14, 2005
- Ottawa, ON
- 96 Ranger XLT 4x4 Xcab
Hi, I wonder if anyone has any clues to what might be happening to my truck (96 Ranger 4x4 xcab, auto, electric BW1354). Sometimes, seemingly randomly, usually while accelerating though, suddenly a whirring/ratcheting sound starts up. Sounds like it is coming from underneath the middle area (trans/t case/ rear driveshaft). Almost like a card-in-bicycle-spokes noise. It is tied to the speed of the driveshaft, I think. (sound slows down as I slow down). You can feel a vibration and hear the ratcheting, but otherwise it seems to drive fine. Then, once I get to like 10 mph, there is a loud Thump/Clunk (sometimes 2 quick ones) that you can feel thru the floor, and everything is back to normal, usually for many more drives. But it happened yesterday and today, after not happening for like a month. The previous times it happened, it was within 5 minutes of using 4x4 to get out of an icy patch, so I thought it might be related. But today and yesterday I was never in 4wd.
In a seperate diagnosis for front end popping noises while turning, I was told I need 2 upper ball joints, and the front axle u-joints are "seizing". I don't think it is related though, because I don't think the front axle is turning when the truck is in 2wd and autohubs unlocked...right? Could this noise be rear u-joints? t-case or hanger bearing? rear end (dont think so, the thump feels like it comes from the middle), trans?
All input appreciated!
ps. My search came up with whirring and ratcheting noise issues for auto-4wd t-cases, and usually when letting Off the gas. My problem is different, it happens when you are on the gas Or off, and I have the 1354 case (2wd/4wd high/4wd low).
Thank You!!
Thank You!!
