LukerDooker
- March 25, 2013
- sorry nope
- 2013Limited 301A TuxBlack
I had a rattle similar to what you are describing on the passenger side front of my 2014 Sport. I could not tell exactly where it was so I removed the "A" pillar trim and the door trim panel. What I found was the window motor was touching the inner door sheet metal. I tweaked it away from the door by hand (was not hard) and now, no more rattle.
I did not take it to the dealer because it was an intermittent issue and I had no faith they would put any effort into finding it.
I have read on here the same, and mine does this once in a while after the front window motors were replaced due to shuddering windows when going up or down.
Its a metallic tapping sound.
Exterior pillar trim on the passenger side is not clipped in tight on many from 2011 thru 2015? and sounds more like plastic rubbing or plastic squeaking when its moving. Some have had it fly off at hiway speeds.
In a quiet area if you press on it and it gives a bit you will hear it, you can rock it edge to edge slightly just to understand the noise.
With air passing thru it while driving its much louder.
