rear ABS light on | Ford Explorer Forums
rear ABS light on
Bad sensor?
Check you fuse under the steering column. You should have a fuse that is designated for your ABS. I bet you will find it blown!
Brian Green
-2001 Sport Trac (soon)
-1992 2wd Explorer w/
6in suspension lift
-1992 2wd Ranger w/
5.5in suspension lift
-Trckmagik@aol.com
Replaced the ABS sensor - it shouldn't cost more than roughly $35.00. 99.99% of the time its the problem.
Todd, Try a search on ABS. I think there was a thread about a self diagnostic test for the early model explorers. Good luck.
JJW, 92 xlt,4x4
Its a bad "rabs valve" sensor in the rear. I've got a '92 with the same problem. It costs about $330.00 to fix at the dealership (the sensor is about $220.00), but a few mechanic friends of mine said that the braking performance was much better without the rear abs and I agree. The rear abs doesn't help much, only the front in a slide or something like that.
Randy
'92 Explorer, 4.0 & J.E.T. Chip
Are there any known causes for this failure? What about brake fluid thats in poor shape?
Mines a 91 with 165,000 miles and I've never changed it. I've asked my mechanic about it and he doesn't think its a big deal either but I keep reading about how bad bake fluid is bad for ABS systems.
Barry
One of thr reasons that the rear antiloock light turn on is beacause the rabs valvle is litering or loosing brake fluid and i want to know if i can fix the valvle or i have to buy this valvle new and how much does it cost if it posible
Tanks for your help.
Im wondering if someone of you have a photograph for the RABS valvle too.
Check your rabs valvle..
