Rear ABS sensor | Ford Explorer Forums
Rear ABS sensor
carlheard
Charlotte NC
2003 limited
Can anyone give me a clue as to how to replace my rear abs sensor on my 2003 limited. I know itts on top of the diff but cant see it. Am I looking in the wrong place?
abs sensor
If you jack up the frame and let the rearend stay on the ground you should see a wire running to the differential and that wire plugs into the abs sensor. This sensor should be held in by one bolt. It should be really simple to change and runs about $20
