Dylan Baker
- October 2, 2019
- Seattle
- 06 Exp
86 F150
68 Stang
Hello all,
I have been experiencing issues with my rear ac in my 2006 explorer limited for quite some time now. For the past couple years the rear vents have mostly only blown hot air ( they blew cold air maybe once or twice during the past few years). And I don't mean like luke warm air like the mix was wrong, but super hot air. Like full max heat even when the dial is cranked to the coldest setting. I did some research and it sounds like it could be a number of issues, (bad blend door actuator, clogged freon hose, leaks in the rear ac system, bad expansion valve etc.) The problem is that despite all my research I have no idea how to diagnose which of the issues it is, or even where the rear ac system is located in the car so that I can have a look at it. Any suggestions as to what it might be, how to diagnose what the problem is, and where the rear ac system is located would be much appreciated.
Thanks
Thanks
