Rear diff oil confusion. | Ford Explorer Forums - Serious Explorations
Splorin' 461
Minneapolis, MN
03 Limited V8 4WD
2003 V8 Limited 4x4 w/tow package 170000 miles
For a little while now I've been having this strange drag/vibration in the rear. Some here have said that changing their rear diff fluid helps or solves the problem so I thought I would look into it.
When I bought the X in October I had my local shop do some work. I dug back in the paper work and found that the refilled the rear diff w/ synthetic 75w-90. According to the manual that is wrong so I decided to change it out.
According to the manual the rear axle requires synthetic 75w-140 with 4oz of XL-3 Friction Modifier. So I went to the dealer and bought what is needed.
Just now, I damn near have the drain plug out and I happen to notice "75w-90" embossed in the rear diff case.
So my question is, what oil does this thing take and what would you do?
Thanks!
Thanks, that's exactly what I needed to see!
75w-140 is what was originally mandated, but then Ford tried going to the lighter fluid for fuel mileage. It didn't work out so great for the LS differential. I run the 75w-140 with friction modifier in mine and it cleared the rear end chatter that existed because of whatever fluid was in it when I bought it.
