Rear door won't open internally.. | Ford Explorer Forums
Sid Daley
Surrey B.C.
97 XLT Sohc
My daughter was opening the door from inside earlier and the door handle became stuck about halfway out, when I tried to push it back in it required a fair amount of pressure to unstick it. It now appears to not do anything as far as opening the door, but functions normally otherwise ( LOL ) ..
I tried removing the door panel but it seems on really good, are their any tips for removing the panel. The truck is a 1997.
Have you checked to make sure the child locks aren't enabled?
Thanks Alec, but that was the first thing I thought of until I seen that the door handle was stuck about halfway between open and closed. Now when I go to use the handle it's still springloaded but doesn't appear to be connected inside the door :-(
Sid
Looks like it's another poorly designed part..
Found these people had the same issue..
http://www.explorerforum.com/forums/showthread.php?s=&threadid=60751&highlight=door+wont+open
http://www.explorerforum.com/forums/showthread.php?s=&threadid=59857&highlight=door+wont+open
http://www.explorerforum.com/forums/showthread.php?s=&threadid=26845&highlight=rear+door+wont+open
Sid
