Rear end | Ford Explorer Forums
Rear end
explrths
Va Beach
'96 x
I have been noticing over the last few weeks that the driver side rear is begining to really sag. Is this a common issue and how do I fix it?
Yes it is common. The gas tank is on the drivers side. Usually both sides will sag.
The cheapest & easiest fix it to put add-a-leafs in both sides. The add-a-leafs will run around $50 for the set.
I Don't know what instalation will cost you though but it shouldnt be to bad.
Ok, so basically it sounds like my leaf packs are starting to fail? If so, I would like to just replace them with a set that also gives my 2 inches more height. I am not fond of the shackle look I have now
