Rear hatch key lock | Page 2 | Ford Explorer Forums
Rear hatch key lock
Buffalo, thanks for all the help & pics! Sorry for the slow response- I usually get emails when someone replies, but I didn't this time around for some reason. Anyways, I took some pics of mine as well. I was able to play with it a bit this weekend, as I had to re-attach the upper-right hinge that came off the rear window (which was great fun to fix). I was able to open the window afterwards by just nudging the latch towards the open position.
I think the main problem now is that there is just a bit too much play in it. I stuffed a piece of cloth on the back of it (red arrow) to reduce the vibration for now, but I need to look at it again to see if that is the main source, or if the window arm also needs re-padded to fill the latch completely (the cloth piece that wraps it fell off). It will help if I can look at another one, to see which areas can afford play and how much. I'll try to check out my neighbors or something.
That is adjustable,meaning its mounted on slotted holes,crack the 2 nuts loose and push it inward a bit and retighten the nuts.That should take care of the rattle.
Looks like it's already forward as much as it can go...but good thinking.
