Fisher_White
- April 14, 2015
- Texas
- Red 98 Eddie Bauer V8 2WD
About 5 days ago, I decided to try to fix an alignment issue with the rear liftgate of my '98 explorer (there was a slight gap in between the passenger side rear quarterglass window and the rear liftgate, but not on the drivers side). I just barely loosened the four bolts that hold the rear hatch to the hinges, adjusted the door, and then began to close the door to check the fit when the whole door slipped down and shut itself closed! (Note: I had just removed the latches to repair the actuator, so it didn't actually latch closed).
When I tried to pull up on the liftgate to open it back up, I was able to open it for about a foot and a half before I was met with a very load GROAN- the door had shifted a great deal when it slipped, and the top lip of the rear liftgate was being pushed into the very rear edge of the roofline of the truck. Unfortunately, this caused a very slight buckle on the top of the door (see pics), and the 1.5 foot opening made adjusting the door again very difficult with a socket set.
Fortunately, with the help of a friend a few days ago, we were able to get the door open all of the way by squeezing into the 1.5' gap and using a small 8mm wrench to loosen the bolts more to adjust the door. Now, the door opens and closes freely without hitting the roofline, but there is now an even bigger gap on the right side, and now, the top and right side of the door.
I have repeatedly tried adjusting the bolts where I has previously loosened them (where the hinge meets the door) with no success of getting rid of the gaps. I have no idea whats causing the issue, so I'm hoping someone on here might know how to fix it (hopefully, without needing to replace the entire hatch- most of the buckle can't even be felt, and the two areas where you can feel it are very small and not that deep).
PICTURES: https://www.flickr.com/photos/76191390@N03/albums/72157681096828425
