Rear passenger window problem | Ford Explorer Forums
suittech
houston,texas
2002 ford exploder
Ok. So my window wouldn't go up or down using the power buttons. But I still could hear the motor running and some weird noises. Friends tell me "It's probally just off track - easy fix".
Then I take off the inside panel and im looking at this:
Then I remove the (what I'll call) motor:
My question is should I take this apart and try to fix the cables ? Are they even "fixable" ? Or just order a new one ?
Ok update. Got bored and decided to take things apart and have a look:
So .. uh now what?
Mine did the same, got a new one from NAPA for $89
easy to change out except for removing the stock rivets
I changed mine. Just took a large drill bit and drilled straight through the door and onto the rivit. Put new regulator in and used a bolt/nut/lockwasher to bring it back together. So far, so good:)
Are the front and rear regulators inter-changeable?
And now I know what the part is actually called .. I thought the whole thing was the motor. But its the regulator. Cool. Thx.
i am not sure if i am allowed to post this but i am parting out a 1997 explorer and have a regulator i will sell
No I don't think the front and rear regulators are interchangable.
MK3-And I am sure yours wouldn't work.
oops sorry i am a silly
and did not realize i jumped generation threads
