arco777
- April 6, 2008
- 1994 Explorer 2dr 4x4
My right rear turn signal/brake indicator isn't operating correctly. Ground is good, night running light circuit works, but the 12V "pulse" circuit for brake/turn/hazard isn't working. Left indicator, third brake light, and front signals are working correctly. The indicator light on the dash for the right turn signal illuminates as normal and the front right turn signal is fine.
Voltmeter readings are sporadic but indicate a pulse of only around 5 volts when it should be 12. I have traced the wire (orange/light blue) forward from the socket to behind the right rear speaker is and it has normal resistance. Can't figure out where it goes from there, under the carpet maybe as it's not under the right door sill.
Any idea why I'd only be getting 5 volts on the right turn signal? Could it be a short somewhere? If so, where does the wire run? Thanks!
EDIT 2: Tilting the wheel up has no effect.
