emfjsullivan
- July 29, 2002
- herdnon, va
- Navajo (Explorer Spt) '93
I've got a 93 Mazda Navajo that's been running great for the 2 years I've had it. Just recently, it's started to shake/buck when shifting from 1st-2nd (it's a 5 speed manual xmission) and 2nd-3rd like there's a problem w/ the engine/xmission linkage. The engine seems to still run smoothly when idling and when it revs up when stepping on the gas while in neutral, so I "think" the engine (ie gas and spark) is ok.
The other issues I have are the valves/lifters tapping for the first 3-4 minutes after starting; plus a small oil leak that was never totally corrected (even after $700), and an A/C (has the 134a freon) system that doesn't work too well unless I'm above 2000 rpm consistently (which means very uncomfortable temp while in traffic in the DC/Northern VA area in the summer).
It's got 115k miles (body is fine) and I love the truck but I'm at a point where I either put some $ into overhauling the engine and the tranny to get it into tip-top shape or dump it and go for a new one. I'm looking for opinions on going for an engine rebuild vs. having someone install a remanufactured engine, and getting the transmission rebuilt. I'm not sure what it will cost in this area, but it's got to be alot less than a new $25k Explorer or Escape.
Anyone have any suggestions on which way to go?
Thanks
Thanks
