Remote not working | Ford Explorer Forums
Remote not working
LBJerryH
Nashville, TN
1996 XLT
Ok, I am new to the forum and I have a very odd question. About a month ago, my remote stopped working. I couldn't unlock, lock, panic or anything. Also, my Theft Light on the dash would not come on when I would lock the doors, which it always does. Well, it started working a couple of days later, so I didn't think it was the battery in the remote. It started doing this again yesterday. And the Theft light won't come on and I can't use the keyless entry pad on the drivers door either. What could the problem be???? :(
Hey man, just saw you ask about this over on 3.8. I think that from what I could find, you are able to "resynch" your remote with the main control box thing and that might help. I found a few other posts similar to this and no one really ever found an answer. Hope someone that knows for sure can chime in. :cool:
Thanks man. Me too. This is really getting on my nerves. I hope it isn't an electrical problem. :(
Potentially, its a loose wire at your PATS... check to ensure that it has battery and grd when your "no theft light" condition shows up. I think the remote not working is just another symptom of the PATS being "dead".
This same thing happened to my '95 xlt. It is probably a bad rap (remote antitheft personality) module- located in the jack compartment mounted on the wheel well, driver's side. You might want to unplug/replug it to see if it will reset. I found one on ebay and it solved all the problems you describe. Try searching this forum for rap module or anti theft-I know I've seen pictures of it.
