Removeing the rocker panel plastic guard? | Ford Explorer Forums
Capt Caper
Whitefield N.H.
95 Sport
What do I need to do to remove the plastic guard on the rocker panel on my 95 Sport? I have some rust coming through and need to patch it up for inspection.
Jim
I assume they are the same as the tuberware on my '93... The lower part is held in by a dozen or so push pins will the upper part has a dozen or so clips. I just grabbed the plastic trim and pulled up and out (like dman726749 indicated) and it just starting coming off. Once you get some off you'll see what I mean..
BTW there was a single screw in the front and rear fender well that needs to be removed first...
Well, I take a little bit more of a " reusable " approach.
I have these " Mechanic Picks " I pull out on the moulding enough to peek in and see the " Feet " on the clips, I reach in with the pick and relaese the little feet and walk the thing off.
I know my description sucks with out being able to see what I am talking about.
Thanks guys
I didn't get the email notifications or I would have replied awhile ago.
I tried to call you :rolleyes:
