Removing Evap Purge Valve | Ford Explorer Forums
Marcel Kelley
2014 limited
I know this may be a stupid question, but how do I remove the bottom vacuum line from the evap purge valve? It's the clip with the green prongs on it that I can't seem to get off no matter what I do. What is the trick to getting it off so I can replace the purge valve?
Welcome to the Forum Marcel.:wave:
I don't believe this subject has come up before. Hopefully a more knowledgeable member will be able to assist you with this.
Were you able to replace the purge valve? I have a 2017 Sport and I can't seem to find where exactly it's located.
I don't think I'd be waiting for a reply. That was the member's first and only post (July 19, 2017).
