removing front axles on 02 explorer when pulling engine | Ford Explorer Forums - Serious Explorations
sko57
euclid ohio
2002 eddie baur
Pulling the engine on my 02 explorer, book says to remove the front axles, is that really necessary or is it a clearance issue that can be resolved by dropping the oil pan? thanx for your help
i didnt when i pulled mine, i just removed a bolt on the motor mount on the driver and pass side (made install a little more tricky due to the need to realign the holes, but much less trouble than pulling axels). are you 4.0 or 4.6?
sorry bout that, 4.0, sucked a valve
the motor mounts are two pieces correct? you should still be able to remove the engine with removing hte axels.
yep, 2 piece mounts, when I was under the truck I could'nt see a prob, was wondering if I missed something
shouldnt be an issue, my manual wanted me to drop the whole front differential lol...needless to say, that didnt happen.
