Removing stock radio/head unit trim? | Ford Explorer Forums
Canton, ohio
'97 XLT 5.0L V8
I have a 97 explorer still with the stock radio. I am wondering how to get it out so i can put in a head unit. Also i can not find the trim to fill up the space left over after the head unit is in place.
the 4 small holes need a tool so the radio just slides out really easy. I bought my din removel tool and dash kit from Walmart Good Luck
use a coat hanger...not worth spending $ when you have the tool in your house
if you do not have that either.. you can remove the whoe Bezel and remove the radio from the bezel from the rear of the bezel.
the din removal tool is only $3-4, the radio surrounds are $10 (all at walmart)... I just bought one today
Question, though... on my 05 explorer do I need to take the part surrounding the radio out in order to change radios?
Yea, you have to pull the surround off to access the radio. Its bolted in.
Buy the Din tool if you need to remove your radio. Works much easier. Advance Auto, Walmart, Local audio place, will have the spacer and wiring harness you need.
it is very simple just pulls off..
