Repairing o2 sensor wiring bank 1 sensor 1 | Ford Explorer Forums
Kickingback99
06EB2wd
the connector on the harness side going to the pcm, has got bare wires where the plastic sheathing has fallen off causing a. Error code p0135 for the o2 sensor. I am trying to find how the wiring is ran so that I can get at the connector to repair. But cannot seem to trace it back to the top side to have enough room to repair it. Any suggestions? This is a 2006 Eddie Bauer v6 2wd. The sensor is showing resistance when I test the two white wires. I can see copper wires coming out of the connector on the pcm side of the harness.
Any help appreciated
I noticed the 2nd generations had a transmission access panel under the dash better access to the connectors, does anyone know if this is true of the 4th generation?
