Replaced Caliper...new one leaks... | Ford Explorer Forums
MM2(SS)
Groton, CT
'02 XLT
I just put on...
monroe shocks
monroe struts
BTF spacers
all new break pads
and a new right rear caliper
Needless to say I was really pumped to get this bugger off those jack stands and on the street. Before I could go anywhere I was doing some final checks, and saw the leak.
Where the break line taps into the caliper (shaped like a 1"x1"x1/4" square) is totally leaking approx 1 drip per min. I really need some help getting this sucker not to leak. Anyone have any ideas?
lol where do the washers go?
got some washers in... that leak stopped
Now I'm bleeding the lines and I am building up zero pressure on the pedal. I have gone through about one liter of DOT-3 and have no idea what to do.
I have a guy on the pedal and I am in the back bleeding away. I appear to be getting no air but there is no pressure buildup. Any ideas on what is happening or what i'm doing wrong?
My thought is that I need to just keep going with what i'm doing.
If you let the brake system completely drain, there may be air in the ABS pump.
The only way that I know of to bleed the ABS pump is to cycle the solenoids while bleeding the system, which requires a specialty tool (scanner).
