mr cribb
US Army Retired
- December 16, 2010
- Naylor, MO
- 98 Z71, 89 stepside
I have finally replaced my clutch and slave today. Fortunately being military I have access to an on post repair shop. My biggest complaint:
trying to remove the slave line... the "white tab" that is supposed to be there according to ASE mechanics and the haynes manual... was NOT there. I was about to give up when one of the ASE techs came over with a thin piece of aluminum to wedge in.... after several hours of frustration and P**sing with it it finally came undone. The sad part is the shop closed up at 5pm so I couldn't get it done today.
All that is left is to bolt on the starter, xmsn x member, drive shaft, and exhaust. Then bleed the new slave.
My findings when I pulled out the old clutch was amazing to say the least. I want to say that it was a full 201k, the pressure plate was worn down a 1/16th - 1/8th inch (there was a worn lip on it), the clutch disc was down to rivets... (no wonder I couldn't pull up a hill in 2nd gear, much less 4th was almost non-existent. The slave looked fine, and I had outstanding pressure.
When I compared the new slave from Tousley Ford to my old one it said "made in Mexico" but had all the identical markings and numbers as the new one. I did go ahead and install the new one, just due to the PITA it is to put in.
All in all thank you to the explorer forum for posting the issues and tiring BS involved in tackling the job. I have learned lots. And I hope the slave bleeding goes with out a hitch. I need the truck for monday morning. I have 8 hrs to work on it tomorrow. I hope and pray it all works out.
