replacement of spare tire | Ford Explorer Forums
Explorer Pete
Sacramento, Ca.
2013 Explorer Limited 4WD
I have a 08 Escape, the spare is the space saver type. I was thinking of changing to a full size tire. Would I need to get the air pressure sensor for the spare? If that is the case, how do I connect it up to the on board computer? What other possible problems might incure? Pete
You are probably better off keeping the space saver, since as a temporary spare, it's the best option to save space/weight and therefore, fuel.
A full size spare is mostly for older or heavy duty vehicles that might need to have a long-term solution if they get a flat. An Escape, like most modern vehicles, is designed more for fuel savings and basic transportation, with the expectation that you can just throw the spare on if you get a flat, then make your way to a shop and get the flat tire repaired or replaced.
You can certainly replace the space saver with a full size wheel if you want, but you wouldn't use a fifth air pressure sensor if that's how the system works. A pressure monitoring system would only expect four tires, unless it has special readings for the spare as well, and even then, it would probably expect the higher pressure of a space saver spare, not the regular pressure of the full size tire. Most tire pressure monitoring systems just use the diameter of the tire when rolling rather than internal pressure sensors though, when a tire rolls faster than expected, the system reads it as being low on air or flat.
if you tow anything, a full size spare could be a good idea in my opinion. strictly speaking as it being for spare tire use, i wouldnt worry about getting a tpms set up for it since it should be used in an emergency situation. i wouldnt worry about tripping the tire light if it ever gets used.
i actually have a full size on my Ex. I'm doing a five tire rotation. . .i have the viscous clutch. I find with the five tires rotations are easy, and if i have a blow out at more than half life i can switch to a four tire rotation without any worry.
Notes:
Make sure it fits, sometimes the space for the donut will not allow a full size to fit.
I had to get an extra TPMS sensor for the extra rim, make sure it the correct one.
I also have to reprogram the TPMS on a rotation, mine just requires a magnet, newer is a garage door opening looking thins. Takes a total of 10min to do.
